Carbon vs Ali wheels (Braking surface)
DWiggy
Cobham
I knock out a few hilly commuting miles and go through about 2 set's of wheels a year, each only getting about 5k miles before the braking surface becomes worryingly concave.
Just a though but would a carbon set of wheels last longer, I wouldn't mind spending extra if they lasted longer?
Failing that it's moving over to disc's but that's a new bike!
Loch side.
They don't last half as long and provide much poorer braking. Stick to alu or go for discs. A disc frame may even cost less than a set of fancy carbon wheels.
Also, you say worrying concave? How much latitude do you allow before swapping rims. 1mm?
Finally, have you tried Koolstop Salmon pads? These reduce rim wear significantly.
DWiggy
DWiggy
Cobham
...They follow the shape of the end of my finger! and yep I use either Koolstop or Swisstop bot really good
jowwy
Not here offten enough to argue
I would look into buying a disc braked commuter......then its just pads that wear and not the wheels. Can always use nice carbon wheels then too, without worrying about winter grime and sludge wearing them down
DWiggy
DWiggy
Cobham
Thought about a disc commuter/all rounder, will have to have a think about saving for one!
Tim Hall
Crawley
But if the rim is very thick to start with, you might not need to change it. Get busy with a measuring gauge, like this one, and replace when thickness < 1mm. Or buy rims with rear indicators built in.
