cavity wall insulation
Not me
Yes
Yes
No
sheddy
Suffolk
All those I know who've had it done seem happy
But Jeff Howell who writes in the Torygraph isn't. Also my Dad. I guess I'll have it done after he takes his last taxi
byegad
NE England
As an Asthma suffer with a particular allergy to hydrocarbons I've not done mine. When next door (terrace house) had it done I wheezed for a couple of weeks. I'd rather be cold!
summerdays
Cycling in the sun
Bristol
I had mine done years ago - I think it works - although I would say that I think it holds the heat in summer hot days too (now trying to work out how to stop the house heating up in summer). Other people are often suprised that we haven't got the heating on during the day in winter ... so it obviously traps some heat.
No damp problems.
Haitch
Flim Flormally
Netherlands
We had it done a couple of years ago and it was well worth it. The heating bill dropped by about 50 pounds a year. The guys ("insulation installation technicians") drilled a few holes in the outer wall and pumped foam into the cavity. They were finished in a couple of hours. It might be worth asking whether you can get a grant from someone (local council?), what with it being all green and that. The only thing the foam-spouters were concerned about were vents in the walls. If there are any, they have to be sealed otherwise the foam oozes out and dribbles down yer Anaglypta.
Abitrary
Gerry Attrick said:
Had mine done two years ago. Best thing I ever did. It's a raw wind on these wolds.
C'mon. It's good but not that good.
bonj2
Do it yourself. Just get a load fibreglass, and if you've got double-thickness walls, then it's easy, just stuff it down between 'em. If you haven't, it's a bit more difficult - but not much more, you're just going to need to nail it to the wall - and then whack a layer of plasterboard on top. If you called blokes in vans out to do it then that's all they'd do, so you might aswell save yourself the money. Don't fall into the temptation to compress it loads so you can stuff more in, 'cos then it doesn't trap as much air in it and isn't as insulative.
bonj2
Oh, another tip - if you need to knock any bricks out, make sure you stand inside your house and knock outwards - NOT the other way round! For obvious safety reasons - you don't want your house falling down.
Abitrary
If you decide not to do it yourself, make sure you get a receipt though, and keep it in a plastic envelope
bonj2
Occasionally Bonj I worry that you're getting too boring, and miss the old bonj.
then you post class like this. Thanks.
:biggrin: Your choice. Get milked through the nose if you want.
