Fifelad
- Carnock,Fife
Going demented, changing beautifully through the gears but for every 20 times its ok boom it dumps off the front ring ,especially under tension. Usual checks low/high limit screws set fine.Took into the LBS and they have checked my own efforts at tuning the gears, everything ok, they have even checked the frame, a new front changer fitted also. The LBS mechanic did notice that the REAR mech hanger was a bit off so sraightened it. Worked a treat until nearly back at the house and off it went again. The rear mech is worn and needs changed anyway.I am assuming the if the rear mech is a bit off it could affect the changing at the front? only other thing I can think off is that the front chain rings could be replaced although they are not that bad and should have a bit of life left in them yet.Has anyone had a similiar scenario ? opinions please
