Chain lube
Which would you recommend
  • Muc-Off C3 Ceramic dry lube
    Votes: 0 0.0%
  • Squirt chain lube
    Votes: 0 0.0%
  • Other
    Votes: 8 100.0%
  • Total voters
    8
stuarttunstall
Yorkshire Wolds
Hi
I need to get me some more chain lube, usually use the dry lube as 95% the time I am out in dry conditions....
Currently I use the Muc-Off C3 ceramic dry lube but have heard that Squirt is a good option..
Out the two which would you recommend?
Stuart
Dogtrousers
Kilometre nibbler
Just use something. There are many varieties of something and they aren't all that different to each other. But they are very different to the alternative, which is nothing. That is not to be recommended.
Profpointy
I use car engine oil, primarily because I have nearly a gallon of the wrong grade for my car. Arguably a slightly thinner oil like 3-in-1 might be better but cycle chains are not critical nor highly-stressed so what matters is that they are lubricated not neglected rather than what specific combination of whale oil and teflon you are using
