summerdays
Cycling in the sun
- Bristol
I notice this noise when I'm changing gear, specifically its when I change up to the large chain ring (I think its when I change up, I've forgotten now I'm off the bike), I sort of get a noise but not every time. Now I spent some time on a cycle path changing up and down to see if I could work out what is happening. The only thing I noticed was that on the occasions I got the noise the dérailleur had pulled forward, slowish and then slaps backwards generating the noise. Then it appears to be under normal tension. Other times when I don't get the noise it doesn't move as far forward.
Now is this an adjustment needed (to what) or a new dérailleur? (or part of).
It doesn't happen when changing between the small and middle rings.
