confusedcyclist
HELP!
On the way into work yesterday my chain started dropping repeatedly. On the way home my chain snapped, as I pulled over at the kerb it rolled off the cassette and fell down a storm drain (there's a tale for the kids!)
Luckily I was near a Halfords and was able to coast most of the way downhill for a replacement chain. The return journey home was a bit smoother, but I still noticed issues while in low gear, particularly when the gears were in extremes. (I don't normally ride with gears in extremes for prolonged periods, just if I get caught by surprise at a light etc.)
I noticed when I got home that sometimes with the cassette on largest cog and chain on the outer largest (ring) the chain mounts the tips of the sprockets. The chainring doesn't look particularly worn, no obvious broken teeth or bends, and stifflinks can be ruled out with the new chain. I tried moving the stop limiter on the FD for the outer chainring but still having problems. I found the image below which seems to resemble the issue, but it's not my bike so don't go by what you can see there. The FD hasn't twisted on the seat post either. What am I missing?
This issue has appeared spontaneously, I haven't done any adjustments to the FD etc and the bike is well serviced and lubricated, the gear cable is relatively new as well, this leads me to believe it might be wear on the chainring, I'll post my own images later if required.
Thoughts?
Thoughts?
