chris folder
Hi has anyone ever changed there chain because of chain stretch?
Jeez! I hope YS doesn't see this.......Hi has anyone ever changed there chain because of chain stretch?
So do I. That's the type of thing they say drives him to drink.Jeez! I hope YS doesn't see this.......
I have a chain gauge and have replaced my chain when it's 0.5% in the past.... but these days I'm more inclined to let the chain, chain rings and cassette wear out in unison, and after about X years when it all starts slipping, i'll replace the lot. There is no science behind this but i have a hunch that it's going to be a little cheaper and easier in the long run.
I very much doubt your rear sprocket teeth are pointed.Hi 12boy yep the chain is worn and slack to and sprocket teeth on back wheel are pointed the front sprocket looks ok I was going to order the chain and back 2 sprockets and leave front main sprocket how big should the gaps be between each teeth on main sprocket I wounder? Could you measure your front sprocket gaps between teeth? Or would you say to look for pointed teeth like back showing for wear?
Hi ok well if I go say up hill or put hard pressure on pedals my chain snaps like it off gear yet all gears set ok. Do this sound like a worn Chain? What about the back sprockets is there anything to look for if worn? they look all straight in line
How can half be pointed and half square? Surely they all wear at the same rate and in the same mode?Not all of them around half not sort of square shape the teeth more poined why would you say just change the chain?
