[QUOTE 4915345, member: 9609"]may be he means the chain ring, they wear more where you apply the power so some of those go pointy and some don't. I turn mine on the crank a fifth of a turn occasionally to try and keep the wear even..[/QUOTE]
Maybe you are right. I based my statements on this text of his:
Hi 12boy
yep the chain is worn and slack to and sprocket teeth on back wheel are pointed the front sprocket looks ok I was going to order the chain and back 2 sprockets and leave front main sprocket how big should the gaps be between each teeth on main sprocket I wounder? Could you measure your front sprocket gaps between teeth?
Or would you say to look for pointed teeth like back showing for wear?
God alone knows what it means. More punctuation and less emoticons would help. I just have to keep on reinforcing that wear patterns differ from front to back.
for reasons I don't quite understand the teeth on cassettes don't go pointy, they seem to wear out with little visual sign.[/QUOTE]
The reasons are outlined in detail in "the book".
Hi 12boy
- I'm getting close to the 2% one chain is at 1.9 and the other 3 are round the 1.6, 1.7 mark, may be another month.[/QUOTE]
I'm whetting my teeth for those.
