Chainring. Swap
Thomson
Hi total bike noob here.
Looking to buy a cannondale 2019 synapse Tiagra disc.
Comes with a fsa megaexo bottom bracket and a fsa omega alloy 50.34 chainring. I would like to swap the chain ring for a Shimano Tiagra 4700 50.34 chainring. Just so it matches and keeps the group set the same.
Would this be possible? If somebody could find out or help it would be very much appreciated as I havnt a clue.
Many thanks.
The mega Exo Bottom bracket spindle hole is 30mm, the hollowtech 2 spindle ( Tiagra ) is 24 mm. You’ll need reducer shims or a full bottom bracket adaptor.
Actually I think the mega exo is a 24mm spindle on this bike. I don’t know if the lengths of the mega exo and Shimano spindles are the same though.
T
Thomson
Thanks for the replies. I know there’s probably no need to change it but I would just like it to match that’s all.
Thanks both off you :-)
ianc6472
Member
I have a 68mm/122.5mm Bottom Bracket with 3 gears, I want to change to a single chain ring.
My question is, as my BB is shot, do I need a smaller BB spindle size?
Are you asking if the spindle length needs to be shorter?
ianc6472
Member
Yes do I need a shorter spindle?
Logic tells me that I will need a shorter one! But I’m not sure that the new Chain ring would, should be in the same place as the smallest ring from the old 3 set?? That would also be logical wouldn’t it??? Or does it matter as the chain moves over 3 different positions anyway!
It’s got me beat as the only way of knowing is to try all of them, or is there a logical method of working it out?
A 117.5mm spindle would be ideal, but the one you have will still work, but the ring will be a bit further from the stays.
ianc6472
Member
Thanks for the reply, my choice is 113mm, 118mm or get a new 122.5mm so middle of the road it will be then.... or maybe I will try my old shot 122.5mm first for size to see where I’m at, then go from there. Thanks again
ianc6472
Member
I have an 8 speed on the back so I’m aiming for about middle of the set. Decided the plan is to measure it from the old BB, but I’m sure your right it will be 118mm
