EasyPeez
- Cottingham, East Yorkshire
I shall soon be swapping my headsets.
I'm reasonably confident in servicing my current headset - taking it apart, greasing bearings, putting back together etc
I've never changed a headset before, but I had assumed (perhaps naively) that it would just be a case of taking the current one apart, stacking it in the right order on the workbench and fitting the new one with the corresponding parts in the same order. Is there a bit more to it than this?
Having just read through the Hope tech manual there's a few bits that are beyond my comfort zone. These bits for example -
"If necessary ream the bore and face each end of the head tube. Chamfer the inside edges of the head tube at both ends."
Is this just for a completely new build with a new frame? Can I assume that I can ignore this?
"Press in both cups (2 and 3) using a headset press fitted with Hope adaptors. Use the laser etched Hope logo to ensure the cups are fitted in the correct end of the head tube."
I don't have a headest press or any Hope adaptors. I can fit the cups on my current set by hand. Will a hand/careful use of a rubber mallet suffice with the new one or do I need to buy the things mentioned?
"CUTTING STEERER : Fit forks into frame. Slide the complete top assembly and stem over steerer. Ensure all parts are pushed together firmly. Scribe a line flush with the top of the stem. Remove stem and cut steerer in a straight line 3mm below the line."
Again, I'm hoping this is just relating to a new build? If my steerer is correct length now then no reason to expect to have to alter it to work with a new headset, or is there?
I've tried a couple of Youtube vids but can't find much specific to Hope headsets other than the odd new-build project.
Any advice from anyone with experience of fitting Hope Conventional headsets much appreciated.
Cheers,
Andy
Cheers,
Andy
