This might be a stupid question but my 15 speed BSO currently has a Shimano 48 38 28 triple crankset, the only problem is, due to my misuse when changing down gear, the gap between the top ring and the next ring down is wide enough to occasionally let the chain drop in between the two rings and Jam. (I avoid this by changing down quickly and hoping I don’t go too far and change all the way down to the little ring, but sometimes it still jams and make the gap wider and the problem worse) I hardly ever use the middle ring and have only used to bottom ring twice in the whole time I’ve had the bike.
My question is I’d like to change the triple for a double, maybe a Shimano 52/ 42 crankset, I’ve a three piece crankset with a square taper, and it’s an older style cup and ball style. The gears are not indexed in anyway and are changed with friction levers on the handlebars. What do I need to look out for? Are there differences in the thickness of the front chaining, and will that affect the chain width? (Bikes currently fitted with a “narrow” chain)
I don’t want to spend a whole lot of cash on it, as I’m getting a new bike in March.
