I have quite a hilly commute with long fast descents which means I'm on my brakes at high speed quite a bit, last year I went through 2 sets of Shimano R501's because the rim had concave severely so replaced with set of hopefully stronger Mavic Ksyrium in combination with some Swis Stop greens.
The wheels were holding up really well with very little sign of wear they had done about 3500miles and the braking surface was smooth and bearings running as smooth as day one, that is until stupidly I replaced the worn out Swiss Stops with Wiggles super cheap Lifeline replacement blocks...why did I do it!!!, within ~300miles for using these the braking surface has scored badly with a many deep ridges, once or twice a week I would have to pick out metal shards stuck in the pads!!, this never happened with the Swiss stops not once did I notice metal stuck in the pads so I have a suspicion that the cheap compound used on the Lifeline pads may contain metal as a braking aid.
So I'm now back on a new set of Swiss Stops which are worth the extra £15 they feel so much better under braking and no grinding/scraping either just hope the damage hasn't shortened the life of my wheels!
So the moral of this story is don't be tight and get the cheapest replacement brake blocks as it might end up costing you a new set of wheels!
