ayceejay
- Rural Quebec
No problem here since the wheel has been invented, if you prefer pushing a sledge I have no problem with that - shove on.
The one position fits all seems to me to be a bit of a compromise.
That's ok then; because with the possible exception of "regular", I don't fit in to any of those categories! But I will continue to use the SPD's purely because they have put a stop to my achilles problem, which was putting me off doing longer rides.Which is why you should definitely remain on flats. There's nothing wrong with that - other than the fact that the majority of regular/sport/competitive/elite/pro cyclists happen to disagree with you.
But .... I chose my words carefully; as one must on this forumbut it's a bit extreme for you claim they have no value for others
).But .... I chose my words carefully; as one must on this forum.
What I said was that they provide SFA performance advantage to your average cyclist. I would still claim that is not far off the mark. Of course it doesn't apply to most on here, who are probably more enthusiastic about cycling than your average cyclist; otherwise they wouldn't be on this forum (although the number of cycle fantasist members of CC seems to be on the up).
The alternative is to buy the pedals with flats on one side and clips on the other and a pair of touring shoes with recessed spds. You can then mix and match however the fancy takes you.
I dont mean cages. You can get pedals which are flat on one side and clips on the other.Trouble with those is if you use the clip in sides, the toe clips on the flat side tend to catch on the ground round corners
Yes, toe straps have been around for years and must therefore convey some advantage, but Brandane can't see one for any form of attaching one's feet to one's bicycle.
I'm sorry, when I used the word 'advantage' I completely forgot that some people only see that word in terms of performance advantages like beating previous Strava times. I just meant that, for me and loads of other people, it makes the bike easier and more comfortable to ride.
