Clipless Commuters...
Discussion in 'Commuting' started by John the Monkey, 29 Nov 2007.
  1. Clipless
    1 vote(s)
    100.0%
  2. Flats + Toeclips
    1 vote(s)
    100.0%
  3. Flats only
    1 vote(s)
    100.0%
  1. They should be known as CLIP-IN pedals in my view. For some reason 'clipless' has become the default term for shoes which have a cleat which engages into spring loaded plates on the pedal. They are called clipless because they were originally an alternative to pedals with toe clips. They dont have toe clips on them and became known as clipless as a result. Rubbish.
  2. HJ
    HJ Cycling in Scotland
    Auld Reekie
    In my experience they do help me to peddle more smoothly and climb better, and yes I do pull the peddle up.
  3. Pete
    Pete Guest
    No, you are not alone. Toe clips for me, for the past 35 years or so. I can wear any shoes I like for the commute and shopping, within reason (trainers with ribbed soles not a good idea), though I use proper hard soled cycling shoes for any distance. Can't get shoe plates these days but that's just something I've accepted. I don't tighten the straps and my feet are perfectly positioned. I have never, ever, had a 'can't-get-foot-off-pedal moment' (I wonder why they're referred to as 'clipless moments'?) and don't expect to.
  4. PrettyboyTim
    PrettyboyTim New Member
    Brighton
    Yes, I was wondering what would have happened if I'd had a clipless setup on my bike rather than toeclips when I had my tumble yesterday. After my knee hit the ground as far as I can tell I was pretty much thrown off the bike and rolled down the road. Nasty graze on my knee from the original contact, but all the other knocks and grazes after that were minor. I wonder if it would have been worse if I had been more securely attached to the bike?
  5. gambatte
    gambatte Middle of the pack...
    S Yorks
    Had regular 'offs' with SPDs and the MTB.
    I'm amazed how I've always managed to get unclipped. Don't know how it happens but its strange to find you're suddenly stood at the side of your bike as it slides away.:smile:
  6. Pete
    Pete Guest
    By 'clipless moments' (or whatever) I wasn't referring to falls for other reasons: e.g. slippery surfaces, being hit by something, etc., where you're going to go down and hurt yourself no matter what pedals.
    No, I mean falls which happen during normal riding, usually when coming to a stop, and are directly caused by being unable to separate foot from pedal. I've witnessed a few of those but don't want to embarrass anyone by naming names...
    In mitigation, this should never happen with an experienced rider who's got accustomed to the pedals.
  7. HJ
    Auld Reekie
    It happens to most cyclist who ride clipless at sometime, who are after all only human, usually after a sudden unexpected stop, but I still prefer to use SPDs to rat traps any day.
  8. Ranger
    Ranger New Member
    Fife borders
    Nearly happened on my first commute with clipless. Most embarrassing thing is that I was stopped at the time with my left foot down and then slowly felt my body tipping to the right. Cue the type of panic I last felt when learning to kayak, lots of twisting of feet and dabbed down just in time:thumbsup:
    Plenty of time on the way home to fall over properly
  9. gambatte
    S Yorks
    Usually after you’ve got through the white water, started to relax and you inadvertently hit the eddy current?:smile:
  10. noggin
    noggin New Member
    flats toeclips fro commuting for me
    go through city centre with loads of daft peds walking out infront of me and at least 23 sets of lights (in 6 miles)
    clipless be of no benefit to me
    the few times I take the road bike to work I really don't enjoy the commute
  11. Elmer Fudd
    Elmer Fudd Miserable Old Bar Steward
    Can I Be thick here (no change there then!) Just how do clipless work ? Do you "snap" the cleat in and out, or is it like a twisting motion ?
    Say I bought some dual pedals, say shimano spd's one side, flats the other, does this mean I am locked in to buying shimano shoes or could I buy any make as long as they accept spd cleats?
    I've only ever ridden with flats + toe clips.
  12. doyler78
    doyler78 Well-Known Member
    Co Down, Ireland
    Basically there is a raised bit on the bottom of the shoe (this comes with the pedals and not the shoes which you bolt on to the shoe) that you push (or clip) into a recess in the pedal (binding). Some pedals are dual sided, some single sided and yet others are flat one side and clip-in the other side.
    SPD's are a specific type of clip-in pedal which is generally considered a mountain bike pedal because this was the market these were created for and the major market that still uses them. Unrecessed clip-in are very slippy and hard to walk in and therefore not good for anyone needing to do a bit of walking off the bike without a change of shoes. For this reason many commuters will use spd's because of their versatility.
    You may ask then why everyone doesn't use them for clipless systems. Well they have a much smaller cleat which means the loading on the foot isn't spread as widely therefore on longer rides some people experience hotspots which can be painful and make cycling difficult therefore those on long hard rides who are forcing every ounce out of each pedal stroke will opt for the wider cleat systems which aren't recessed as they have no plans to do any serious walking as this will help spread the load and thus avoid the problem with hotspots aiding performance.
    SPD (Shimano Pedalling Dynamic) whilst it bears the name Shimano is widely known clipless system which many manufacturers now make compatible shoes for therefore you are not bound to buy shimano shoes (which for some of us are just too narrow to be comfortable), indeed I have specialized body geometry sport mtb shoes to use with my shimano pd-m324 (dual purpose) pedal (ie as you describe - flat one side, spd binding the otherside).
    In order to release yourself from the pedals once clipped in you simple twist your foot outwards and they will release. Most pedals (if not all now) have tension setters which allows the beginner to set them loosely so they can break free easily whilst they get used to twisting out and as cleats wear so the tension needs to be increased to prevent accidental unclipping which could be dangerous (but then again no more dangerous than toe clips which are too tight). Whilst convention is that you should twist outwards for some people, such as myself you have foot probs, twisting outwards may not be an option therefore multi-release cleats can be purchased for most pedals which allow you to twist inwards or outwards as well as pull sharply upwards to release - all these options obviously increase the chance of accidental unclipping therefore tension monitoring will be more important as cleats wear so that this doesn't happen.
    Hope that sort of answers your questions.
  13. HJ
    Auld Reekie
    Damm doyler78 has left nothing more to say....
  14. Elmer Fudd
    Thanks doyler78, I was thinking of the m324s so to start with I could use my left foot on the flat side until I can get used to the unclipping action with my right foot !
    Sadly Xmas comes 1st though !
  15. fossyant
    fossyant Ride It Like You Stole It!
    SPD is the business for commuting, lot's of traffic lights etc. no problem. I never ride a bike without being clipped in - you just can't give it all. Road bikes - I use Looks, OK for commuting where you don't have high instance of stops. SPD are excellent for lots of start / stops.
    Double sided SPD's... the commuters friend !!!
    Dismiss Notice
