CO2 in tyres
compo
Harlow
When I was a kid I recall in science making carbon dioxide. The gas was stored in a jar. To prove we had made CO2 we "poured" the gas over a candle and extinguished the flame. This also proved that CO2 is heavier than air. This has me wondering why people spend hundreds of pounds on ultra lightweight wheels and tyres then fill them up with a gas that is heavier than normal atmospheric air.
This is not an April fool, and is totally light hearted, but is there a measureable difference in weight between air and CO2? I know it wouldn't make a scrap of difference either way. As I stated a while back my mind works in peculiar ways when cycling!
Profpointy
air weighs around 1.3 grammes per litre. C02 will be around 2 if my mental arithmetic serves me.
I can't be bothered working out the volume of a tyre, but say it's a litre - .8 grammes extra - mmm
There used to be a myth that they used helium in racing tyres to save weight - somewhere between 0.1 an 0.2 grammes per litre (again from memory mental arithmetic) ... but helium is very good at leaking out of things, so likely they'd have been cycling on flatish tyres
MikeG
Suffolk
Maths time :smile:
Assuming the cross sectional diameter of a tyre is 25mm, and that it is circular, then the cross sectional area (pi r squared) is 9.8 cm sq. Assuming the midline of the tyre forms a circle 712mm in diameter, then the length (circumference) is 223.6cm. Multiply those together and you get a volume per tyre of 2194CC's, and thus a total of 4388 cc's for a pair of tyres.
Tyres are normally pumped to around 100psi, which is about 7 atmospheres, so multiply the volume by 7, and the total amount of gas in the tyres is 30,700cc, or .0307 cubic metres.
Air weighs 1.2 kg/ cubic m, so 0.307 x 1200 grammes = 36.8 grammes.
Carbon dioxide weighs 1.977 kg/ cubic metre, so 0.307 x 1977 grammes = 60.7 grammes.
60.7 - 36.8 = approx 24 grammes.
Therefore, filling tyres with carbon dioxide will increase each tyres weight by about 12 grammes, or about half an ounce.
Profpointy
Maths time :smile:
duh - I forget the compression thing oh dear !
MikeG
Suffolk
Cross section 25mm gives 9.8 cm2?
1.25 x 1.25 x 3.14
Ooops. Don't know what I did there.
Correction factor applied to the calc.......divide the answer by exactly 2
In other words, the volume is halved, and the weight of gas is halved.....and thus the total saving in weight through using air rather than CO2 is 6 grammes per tyre, or 12 grammes per bike.
Sorry.
compo
compo
Harlow
OK, so tyres filled with CO2 are slightly heavier than when filled with air, though by a miniscule amount.
Thanks all.
