I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
I have been thinking about trying daily cod liver oil for a year or two now. The main reason is I am experiencing some low level joint discomfort. Mainly my arms (shoulders, wrists and fingers but elbows don't seem to be a problem) and also my knees.
Knees are fine when cycling, walking, running to the pie shop or climbing trees, but if I have to get down on the floor or get back up again it isn't the fluid, effortless action it used to be and if I have been kneeling or sat cross-legged for any length of time then unfolding afterwards is accompanied by various grunts and groans
I'll just point out at this point that I am not very old, in fact, I am still the young side of my mid 40s so although not a teenager anymore I am still young, fit and active.
My main problem seems to be periods of immobility. If I cross my legs, doing so isn't a problem but straightening out afterwards has to be done slowly. Likewise, if watching TV and I put my arm out on the back of the sofa or hands on the back of my head, it can be quite painful to move after several minutes in that position.
I suppose I have two questions really,
1, is cod liver oil likely to improve matters with long term use (I am aware that I am probably looking at using for life if it helps)?
2, which is a good cod liver oil to buy? Some preliminary reading suggests quality, taste and composition can vary enormously (and cost too!). Cost is almost irrelevant if it means I will still be setting 1hr cycling records when I am 105 years old but I will happily use the stuff off the shelf in the supermarket if any old cod liver oil will do the job for my joint problem.
Any and all advice welcome.
Skol
Skol
