Mr. Cow
- Manchester
Hey,
Recently bought a place and finally have my own gardens
problem is I am a complete novice when it comes to gardening.
At the moment the front is just a paved driveway and strip of grass. I'd like to plant some hedging along the edges of the grass for a bit of privacy. Not decided on the type of hedging yet, was thinking conifers of some sort.
To reduce weeds coming up can I use a weed membrane? If so do I plant the hedges on top of the weed membrane as this way I can't see how the roots can take hold but then how else would the weeds be prevented from coming up. Or do I put the weed membrane down afterwards?
I am thinking of topping off with decorative slate/shingles. But if doing this how do you then periodically mulch? As this would mean removing the slate which sounds like a right faff.
Also if I am topping off with slate do I need a weed membrane at all or will the slate reduce the weeds popping up?
Thanks
Thanks
