Blimey, if you though cyclist were a bunch of fixated nerds, then we are in the wrong game !
Would this work just running it buy you see what you think first grow just putting information that I have collected for my own plan
What I want is a very simple setup up thinking deep water culture 12 or 8 x 5 gallon buckets easy like this
View: http://www.youtube.com/watch?v=ts0iaPRuPjM
In 8′x10′ room in groups or 2 or 3 each under 4 X 1000 watt hps Hortilux bulbs just a straight grow
Is there much advantage to sog or scrog or supercroping what’s your take on those methods would I get more yield from any of these procedures all things being equal in the same amount of space and time?
Could you guesstimate percentage of increase in yield in same amount of space and time?
I read an article that yield is defined by the wattage of light 1 pound per 1000 watts if your lucky is this correct?
Going to be growing White Widow Flowering period: 60 days
Indoor yield: 500 g/m2 And or Holy Grail Kush Flowering Time: 8-9 weeks. Yield: 500-650 g/m2
If one has higher or lower gr/m2 does it matter if indoor yield dependent on light?
I was thinking of cloning for 2 weeks and vegging for 7 = 9 weeks using 4 x 2’ x 4’ fluorescent fixtures = 4 warm bulbs and 4 cool bulbs in the closet bedroom I want to keep the smell in one room
(2 weeks cloning 7 weeks vegging = 9 weeks and 9 week flowering perpetual cycle)
Thus eliminating need and care and room and light for a mother plant
That’s what I’m trying to achieve I will be using 4 x 1000 watt Hortilux bulbs for each 3 x 5 gallon or 2 x 5 gallon DWC buckets want maximum yield with least amount of pails how much harvest could pull from each plant
If maximum yield defined by wattage of light 1 pound per 1000 watts if you’re lucky is this correct?
Would it be pointless have 3 x 5 gallons pails at let say .33333 pounds each or 2 x 5 gallon pail at .5 pounds each?
I’ll never get a pound per light do you think?
Just want room in case I get lucky do you think a 5 gallon DWC bucket will hold a plant that’s been 2 weeks cloning 7 weeks vegging and 9 week flowering without getting root bound
Looking for the magic number of pails
Any criticism or suggestion welcome
PS: I read an article that said one gram per watt of light that’s 2.20 pounds and another article said 1 pound per 1000 watts
