Re Trangias and the frying issue:
There are 6 solutions
1 - Use the standard issue meths burner and the standard issue frying pan, it works but it's very slow
2 - Swap the standard issue meths burner for a 'Greenheat' tin (Google greenheat, available in all good camping shops) The advantage is that to a degree you can alter the height of the greenheat burner - Cost is a couple of quid
3 - By blocking up the hole the burner rests in in the lower section of the Trangia, you can raise the height of the flame, but this can mean an uneven spread of heat and is dangerous if the stove gets knocked (hense we never teach this method to Scouts)
4 - Use the optional Gas fitting. Well worth getting anyway, cost from £21 via web mail order
5 - For those with money to burn get the optional Trangia multi fuel burner by Primus, you can then run the stove on gas or any inflammable liquid such as petrol, diesel, avgas etc. Cost wrong side of £100
6th option: Don't eat fried food on camp, it's bad for you and difficult to wash up afterwards even with a non-stick pan
Bottom line is it is not really realistic to cook a good old English fry up breakfast on a Trangia using the standard meths burner. However a chili con carne can be done better on a Trangia than it can on a standard stove.
In my opinion they are one of the best camping stoves ever designed, and arguably the lightest stove on the market (as long as you compare like for like, so including pots and pans and fuel to boil one liter of water)
