wickerboi87
i ride a cinelli with a 50(200mm) tooth crank i often find i run out of gears on fast sections is there i higher crank and is it easy to change only really got into bike this summer any help much appreciated
eh?Chainring.
Looks like the predictive text had it's way.
Chainring.
sorry
To help us give you a decent answer to this question, please say how many teeth your (assumed) two chainrings have AND how many teeth on the largest and the smallest sprocket (them's the 'cogs' on the back). The latter will not be 9 teeth - to count them you'll need to use at least one toe (as well as your hand digits). Bonus mark: look to see how long your cranks are (there'll be a number on the back like 172.5 (which is their length in mm)).50t chainring and 9t sprocket give you a gear ratio of 150 inches, which means one of the following three options -smallest gear on back is about 45mm 9 tooth
miscount lol50t chainring and 9t sprocket give you a gear ratio of 150 inches, which means one of the following three options -
1/ You've miscounted the number of teeth
2/ You're cadence (RPM) is far too low
3/ You should enter the Tour de France because on one would live with you
miscount on tooth my bad9T sprocket does not exist in this dimension.
