glenn forger
That seems to me to only make sense had the coroner previously referred to breaches, but I can't see that he did.
I was referring to your comment: "I would have thought that maybe the words in brackets were inserted by the reporter"That seems to me to only make sense had the coroner previously referred to breaches, but I can't see that he did.
The coroner would have made opening remarks - which will be noted by the stenographer and on the official report. I guess, since I wasn't there, that there was an initial reference to the Highway Code and so when he mentioned "They" the reporter had to clarify what "they" was as it wasn't noted up article, well either him, editor or sub.Yes, I see, but the first mention of breaches was in parenthesis. Unless I'm confused?
Riding/driving at a speed enabling the rider to stop in order to avoid unexpected obstacles...
And in the event of step out? Say 6 feet in front of you? I'd suggest the only safe speed in this event is not riding/driving at all.
Ride/drive to the conditions is a very easy but blanket statement to make, however there are an infinite amount of variables contained within "The Conditions", not all of which are readily apparent, or can be planned for or anticipated. <snip>
Just to clarify standard practice: The journalist reported verbatim what the coroner said- "Had they not occurred it could well have meant..."
The [...] is the clarification of what the coroner meant when he said "they".
Recording a verdict of misadventure Mr Brunton said there had been “significant breaches” of the Highway Code.
“There is no doubt that it was a substantial speed for a pushbike bearing in mind the atrocious conditions.”
The cyclist “should have been travelling at a reasonable speed for the conditions,” he said adding that “poor street lighting” and “excessive speed for the circumstances” caused the collision.
“Had they [the breaches of the Highway Code] not occurred it could well have meant that the collision would not have occurred,” said Mr Brunton.
Dunno. Is it definite that the coroner is referring to the bike lights as breaches then?
Yeah, the original report from the Cambrian Times wasn't that clear either.By no means, the only specific references are to the street lighting, which have nothing to do with the HC, and what he describes as "excessive speed".
I didn't think there was a legal limit for bikes.The original point at discussion is the valid description of 25mph being excessive in this case versus the reluctance of coroners being prepared to criticise car drivers in similar fashion where a legal limit is not being exceeded. Glenn's point is perfectly valid.
ok, braking in a car at relatively low speed for that type of vehicle as opposed to braking on a bike at relatively high speed for it, and the number & size of the contact patches/chances of losing grip of the respective tyres, particularly on a wet road allied to those respective speeds per vehicle....Yes and no. Look at it from the point of view of someone crossing the road.
What on earth makes you think that? I've got no legislative powers have already recognised there's no speed limit for bikes, but I don't need to pretend a bike and a car are the same physical or kinetic beasts to try and bolster my opinion.Are you going to legislate a different, lower, speed limit for bicycles?
