slowmotion
Quite dreadful
- lost somewhere
Have any parishioners attempted a similar operation. Any advice very welcome.
Thank you.
The what just above the what?What's the joint just above the joist?
I think I'll go back to my coding thread.
If you follow the pipe down, you'll see there's a gap of about 1/2 inch where a joint has been made. Just below where the wall ends.The what just above the what?I think I'll go back to my coding thread.
It's not a joint, just a jubilee clip. I'm going to stick a pair of them either side of the slip couplings so that they don't creep about over time. They are also handy for holding the soil pipe in place while I cut it. Well, that's the idea....What's the joint just above the joist?
He did say a wire saw.Bear Grylls would use one of these
Or his teeth.
I've seen those "Commando saws" on ebay and Amazon. I rather like the sales pitch that they can saw through wood, plastic........and bone.Bear Grylls would use one of these
Or his teeth.
He did. I missed that as I was imagining the results of the angle grinder or rather, trying not too.He did say a wire saw.
The Bond film villain, Jaws, could gnaw through iron pipes but I only have PVC to deal with.It is iron pipe you'll be cutting?
