Crankarm
- Nr Cambridge
Buying an electronic food scale is a worthwhile investment.
An electronic food scale? Right, down to Argos on saturday morning.
Fat ... refuses to go from around the middle.
I've lost ... about 4 inches around my waist
1490 is what MFP gave me to burn 1.5lbs a week.
If that's for the round trip (55min) then that's a very sensible estimate. If that's each way though then I think it's probably over - Endomondo can be very optimistic with its figures.
1.5lb a week is a pretty ambitious rate of weight loss. Bear in mind that's the equivalent of going without food altogether for two days a week. All the more reason to make sure you use up all your daily calorie allowance.
Also, don't worry if you go a bit over the 1490 some days - you're 750 calories under your base rate every day, so if you consume, say, 1800 calories one day, that's still a substantial net deficit.
Slower-Speed Cycling
You will burn 355 calories every 30 minutes if you weigh 185 lbs. and travel at a speed of between 12 and 13.9 mph.
as you can see i've just copied and pasted that from the LIVESTRONG websiteNo you won't. 700 kCal an hour equates to a power output of around 200W. It doesn't take 200W to travel at 12mph, or even 14mph, unless it's up hill all the way. Also, the difference between cycling at 12mph and 14mph would equate to quite a significant difference in power output and therefore calorie expenditure.
I think the OP doing the right thing with his calorie estimate - its probably an underestimate, but better that than a hopeless overestimate.
i'm pretty sure that lance isnt writing the stuff - but if you wanna hate for it be my guestAnd we all know that Lance is never wrong.
d.
Of course it does (or more accurately sometimes can), that goes without saying (obvious to most people). This is a forum though and one needs to assume some common sense from the reader as time is limited and precious.I'm in danger of repeating my sig quote....
It's perfectly possible to live the life of a thin person and remain overweight. Losing weight requires more than just that.
The evidence shows you're actually doing pretty well at shifting the belly fat. It's just that you've got, y'know, quite a lot of it to shift... you're obviously doing the right things though, so you just have to keep it up. It will go eventually.
d.
Great for measuring out the drugs to ensure you get maximum profit for your drugsBuying an electronic food scale is a worthwhile investment.
