Set off on a journey today and within 7-8 miles my chain started slipping badly, there was no warning, it wasn't gradual, it just started happening. I unscrewed* the barrel adjuster a bit and tried all the gears at the side of the road bit but it didn't improve (nor get worse) while actual riding.
*My theory was because the cables are new about 400 miles ago, they'd maybe stretched so needed to be tightened up.
Carried on for another 5 miles with the chain slipping still, before catastrophic failure:
- Hanger snapped at the fixing point to the frame
- Dérailleur (105) bent in several places
- Chain off with 1 outer plate snapped off on one side and bent
- Me in the middle of the road
- No change to limit screws, so the dérailleur shouldn't have found its self in the spokes. I'd heard no rubbing
- Wheel hasn't been taken off for anything
- Chain was approaching, but wasn't yet at the first marker on the chain wear indicator. It was lubricated.
- I unscrewed the barrel adjuster, therefore applying tension to the cable so that should have, if anything, took it away from the spokes?
