Trigger369
Can anyone tell me is there much of a difference in 700×25mm tyres and a 28mm tyre comfort wise .
Thanks
Thanks
I agree comletely however please tell me where I may find a smooth road in the ukI’d say yes if you’ve got the clearance, and aren’t too fussed by a potential tiny loss of speed on smooth (UK) tarmac
You're kidding yourself if you think a tiny 3mm increase in tyre width is going to make any meaningful difference in comfort.
If you want comfort you need a lot more air volume and lower inflation pressures, so you'd be looking at the sort of tyres normally fitted to commuting hybrids and tourers, not skinny road bike sizes!
Northern Ireland roads are terribly rough and bumpy . There is a couple of rides I've done and I won' be taking them routes agian because of the state of the roads.
So would the only difference be speed. Does a 28 80m soak up some of the rough roads?
Thanks
It takes a lot of confidence to drop the tyre pressures, and you feel silly when you finally “risk it”.
I always used to run 100psi with my 75kg body in 25mm tyres. Recently dropped them to about 85psi and thought they looked “flat” when sitting on the bike. Did a 25 mile test and they felt amazing and grip was as good or better. Just couldn’t look down at them whilst riding.![]()
