Dirty water in central heating system.
Globalti
A reputable local family-owned plumbing firm would be cheaper.
newts
Isca Dumnoniorum
I have been in touch with British Gas and they are coming next Thursday to give me a quote. Better use a reputable firm I suppose, far too many charlatans out there.
British Gas are the biggest rogues in the central heating industry! Over inflated charges & poor workmanship.
Power Flushing is a BG cash cow & they rarely do it properly. Beware of their hard sell tactics on new (very overpriced boilers) & boiler care.
Do a postcode search on the Gas Safe website & ask around for recomendations on those local to you.
gavroche
gavroche
Getting old but not past it
North Wales
I am also contacting a local firm for a quote.
MrGrumpy
Huge Member
Fly Fifer
Funnily enough last year we got a quote from BG for a new unvented heating system, they were the cheapest by far out of all the quotes I got. This actually scared me a bit, so i went elsewhere and negotiated a price with a local firm. I went on recommendations in the area.
MrGrumpy
Huge Member
Fly Fifer
I get my system cleaned annually (coming up in October) when I have the boiler serviced. Some years ago, I had one of those magnetic traps fitted which collects the magnetic metal gunk from inside the radiators. The plumber just disconnects it, empties it, puts it back on. Annual service/clean costs me about £100-ish including putting that special cleaning fluid inside the system. This powerflush seems a bit of a rip-off to me..
We had one of those fitted last year when the new heating system went in, can you add inhibitor into that ?
newts
Isca Dumnoniorum
A competent person doing a boiler service should be checking that there's adequate inhibitor within the heating system as part of the service, especially if they've not installed or maintained that system before.
newts
Isca Dumnoniorum
They should have put inhibitor in when thay installed the system, it's part of the boiler install spec. Inhibitor should last for years & not require changing annually. It can be added via the filter depending on type, you'd need to top up the pressure in the heating loop on a sealed system after.
MrGrumpy
Huge Member
Fly Fifer
They did ! all flushed etc ! just im currently getting bathrooms ripped out and new radiators fitted and moved so it’s all gone down the drain ! Might just ask for it to be done again when I get the boiler serviced .
Globalti
You can add inhibitor into the heating header tank. It's only soap, it makes the water alkaline. It might contain a tiny amount of biocide as well, I don't know.
