Vapin' Joe
Formerly known as Smokin Joe
- Bare headed cyclist, Smoker
Brake fade in the heat? Have you ever seen a 150 kilo GP motorcycle nearly stand on it's nose as the rider brakes from 220mph down to 40 when the track temperature is 40c +?Well if you're in the road environment that the UCI regulate:
The brake fade 'cos a disc can't disperse the heat generated in an alpine descent.
The overweight forks that are required to use them.
The issues with compatibility and quick wheel changes.
When these get sorted out then the manufacturers and riders will pressurise the UCI to change (like in cyclo cross).
Forks would not need to be "overweight". Bikes already have to have weight added to come up to the UCI minimum.
Having discs would only marginally slow wheel changes if at all as the wheel just drops straight out. Compatibility doesn't cause problems with different teams using Campag/Shimano/10/11 speed now.
