- Egham
My Boardman currently has a 6 bolt disc front wheel. Can I replace it with a Centrelock one?
Ta
Ta
Yes, exactly that; very easy. I've done the same, though not for the same reason.Assuming the rotor is the same diameter is it fair to say it should be a drop in replacement? I figure I may have to re-align the caliper but that's about all..
I can only find adaptors to fit 6 bolt rotors to a centre lock hub, not the other way round.You can buy adapters to go both ways
There aren't any, you can mount a 6 bolt rotor using an adaptor, but not the other way, as the rotor position would by necessity be moved outboard.I can only find adaptors to fit 6 bolt rotors to a centre lock hub, not the other way round.
http://www.chainreactioncycles.com/shimano-centre-lock-adaptor-sm-rtad05-/rp-prod130953
Please can someone post a link for an adaptor to fit a centre lock rotor onto a 6 bolt hub?
That's what I said could be done. I am waiting for someone to post the 'other' adaptor.......
I know that, my request for someone to post the other adaptor was 'tongue-in-cheek' after two people confidently claimed you could go either way (although I see one person has edited that claim out of their post after I originally posted ).There aren't any, you can mount a 6 bolt rotor using an adaptor, but not the other way, as the rotor position would by necessity be moved outboard.
