Crackle said:Skwerl, I must admit if the flame flexed that much I'd be surprised. I've just been across to my bike to shove it and push it and see again what happens. On mine it would take a fair amount of flex to get the inner chainwheel to touch, and down in the BB area, the whole bike seems to move equally including the rear chain stay.
Could it have been your chainwheel wasn't true due to the crank being badly fitted on the taper or wrong chainweel/BB combination?
No.
If it was badly fitted you'd see it rotate badly when turned by hand.
If it was the wrong combination (which is wasn't) then flex would be irrelevant, it would contact the stay as soon as it was fitted. As I said. the clearance is the same on both frames so how can you explain contact on the IRO but not on the Condor?
Pushing and pulling your frame is not the same as having 90kg stamped down on it under a power stroke.
When you hid BDC there's is going to be a desire for the foot/pedal to try and head towards the centre-line of the frame, as that's where the natural pivot point is. Therefore, you'd expect some sort of movement in the frame as that happens. How much is going to be down to the stiffness of the tubes.
BTW it is isn't the inner. I only have one chain-ring and I imagine it runs closer to the c/s than a road double or triple. There's approx 5mm clearance IIRC
