Bonj if I had a spare, I'd lend you it.
A little reading for you here, its a wiki but theres loads on the web and although more efficient I find the enjoyment comes from not constantly thinking about which gear you are in and just riding
Go on you really owe to yourself to find one and give it a go before your knees make it difficult.
 Derailleur gears
External gearing utilizes derailleurs, which can be placed on both the front chainring and on the rear cluster or cassette, to push the chain to either side, derailing it from one sprocket to a neighboring sprocket. The sides of the sprockets may be sculpted to help catch the chain, pulling it up onto their teeth to change gears. There may be 1 to 3 chainrings, and 5 to 10 sprockets on the cassette or freewheel. Derailleur type mechanisms of a typical mid-range product (of the sort used by serious amateurs) achieve between 88% and 99% mechanical efficiency at 100W. In derailleur mechanisms the highest efficiency is achieved by the larger cogs. Efficiency generally decreases with smaller cog and chainwheel sizes.[1] Derailleur efficiency is also compromised with cross-chaining, or running large-ring to large-cog or small-ring to small-cog. This also results in increased wear because of the lateral deflection of the chain.
Hub gear
Internal hub gearing works by planetary, or epicyclic, gearing, in which the outer case of the hub gear unit turns at a different speed relative to the rear axle depending on which gear is selected. Rear hub gears may offer 2, 3, 4, 5, 6, 7, 8, 9, 12, or 14 speeds. Bottom bracket fittings offer a choice of 2 speeds, and are generally foot-operated. Internal hub gears are immune to adverse weather conditions that affect derailleurs, and often last longer and require less maintenance. However, they may be heavier and/or more expensive, and often do not offer the same range or number of gears. Internal hub gearing still predominates in some regions, particularly on utility bikes, whereas in other regions, such as the USA, external derailleur systems predominate. In a typical hub gear mechanism the mechanical efficiency will be between 82% and 92% depending on the ratio selected. Which ratios are best and worst depends on the specific model of hub gear.
Fixed-gear track racing bikes can achieve transmission efficiencies of over 99% (nearly all the energy put in at the pedals ends up at the wheel). Biomechanical factors however determine that a human can deliver maximum power only over a narrow range of crank rotational speed or cadence. To match the power source with the load under varying conditions, a variable gear ratio is needed, and they work very well, though at the expense of mechanical efficiency. The efficiency varies considerably with the gear ratio being used.
