DMR V12 pedals - advice on adjusting grub screws?
gmtfd
Hi all
After a couple of rides using my new DMR V12 pedals I want to wind the grub screws in, in order to be able to move my feet around a bit more. Even though the pedals are almost new the screws are bloody hard to shift, and I'm worried about causing damage by applying too much force. Does anyone have any tips on the correct way to wind these screws in and out?
Many thanks in advance for any tips / advice!
Gareth
Drago
Use a hard finished, good quality Allen key.
Jody
Stubborn git
Are you sure they aren't already wound in to their limit? Normally you need small grub screws.
G
gmtfd
Thanks chaps! Just ordered up a Park Tool p-handled 2mm hex wrench, hopefully will do the job.
G
gmtfd
Yes I know the pins are there to stop your feet moving about, but I also bought some Five Ten Freeriders to use with the pedals and the combination is just too damn sticky ... I just want to wind the pins in a little to give slightly more freedom of movement.
Heltor Chasca
Out-riding the Black Dog
Therein lies the problem: You are just too good. I’m happy to take the Five Tens off your hands then we’ll both be happy. ^_^
HTH
