woodbine
- Bristol, UK
When I bought my second hand British Eagle MTB in early 90s, it was only 2 or 3 years old and still had the original Shimano smooth-post cantilever brake blocks fitted. I used the bike for several years, commuting daily and occasional pleasure trips - road only. Due to a new job, the bike then languished in the garage for some years before being re-commissioned in 2013.
I carried on using the bike with the original brakes in, but by 2016, the rubber on the blocks was getting a little perished although they still had a little life left in them. So I changed them for new Clarks smooth post CP514 of the same dimension.
The clarks were noisy from day one - not a squeal that you can correct by toeing in the blocks, but a loud rubbing noise that nothing stopped. The main problem was, they wore out in a few months. So this year I thought I would go back to new Shimanos, as the the originals had given excellent service over a number of years. I bought these -
https://www.bikester.co.uk/shimano-br-ct91-v-brake-pad-for-cantilever-brake-357636.html
I fitted these earlier this year, and they're wearing away at a rapid rate too. I only use the bike 2 or 3 times a week for shortish trips. They'll be needing replacement by December.
Why do modern brakes wear so quickly? Are all brakes made of the same soft rubber now? Which brake brand will last longer so that I'm not swapping them every few months? Jagwires?
Thanks for any thoughts or advice.
