That has been explained above (thermal cutouts).But if it's still burning power,surely the elements would burn themselves out? I remember the old electric kettles that didn't have a turn off switch. If left on the elements would be black and burnt out by the time you realised it'd been left on quite a while. These new ones don't burn out,so i'm assuming they turn themselves off when there's no water in
At what point will you use this data to tell you it is time to get a new one?
I would "like" this, but I can't see any mention in the OP that the coffee is instant. Cafetiere and Aeropress coffee both require heating water in a kettle.Actually, I've gone back and re-read the OP, and I've found the root cause of the problem.
Stop drinking instant coffee.
The older, larger ones, come fitted with a spring loaded pin that pushes the mains lead out of the socket, to prevent a fire.But if it's still burning power,surely the elements would burn themselves out? I remember the old electric kettles that didn't have a turn off switch. If left on the elements would be black and burnt out by the time you realised it'd been left on quite a while. These new ones don't burn out,so i'm assuming they turn themselves off when there's no water in
Its talking to the toaster.It's also receiving signals from aliens in space. best cover it in tin foil after use.
And the Russians.Never mind the aliens... the Chinese are listening to everything you do and say via your kettle!!!
Apparently...
Sorry to disagree, but I don't think a picture would give us sufficient intelligence in order to accurately assess the situation, a picture would not enable us to hear the click.. Show us a picture of your kettle and let's see if we can spot where the click happens.
