Does a left on kettle still burn power and if so how much?
John the Monkey
Frivolous Cyclist
Crewe
Sorry to disagree, but I don't think a picture would give us sufficient intelligence in order to accurately assess the situation, a picture would not enable us to hear the click.
If Accy could set up a couple of video cameras (with audio) giving a split screen display showing the kettle and his electric meter I reckon we could resolve this once and for all.
Let's just head to Accy's for a brew. It's the only way to be sure.
Cubist
Still wavin'
Ovver 'thill
Nothing to add to the thread other than the fact a great uncle of mine used to work at Bulpitts/Swan/Goblin in the Black Country back in the 20s and 30s. The company (which became Swan) made the first ever electric kettle with an immersible heating element. My great uncle invented the safety kick out switch which physically ejected the power plug if the kettle boiled dry.
Carry on.
mjr
If you lift the kettle off the base before the kettle has boiled, the switch springs into the 'off' position, so that if you replace the kettle on the base, it is off.
Not all of them do. OTOH mine has farking huge blue(on-at-wall-but-not-boiling)/orange(keep-warm)/red(on) lights to stop me doing the sort of silly thing mentioned in the OP. It goes purple if the thermal cutout activates, so everyone can moan at you until someone remembers how to reset it.
So go buy a new bling kettle and waste energy on manufacturing and transport instead of heating ;)
glasgowcyclist
Charming but somewhat feckless
Scotland
I don't understand what Accy means here. My kettle has a sprung switch that you depress to start boiling the water. If you lift the kettle off the base before the kettle has boiled, the switch springs into the 'off' position, so that if you replace the kettle on the base, it is off. Until you press the switch down, and switch it on again.
The switch on my kettle stays in the 'on' position even when lifted from the base in that scenario. It's a bad design because if you've emptied the kettle, putting it back on the base continues to heat the element until the thermostat kicks in to turn it off. It's maybe 10 years old and I'd hope modern kettles didn't have that failing.
classic33
Leg End Member
Carry on.
Now all that's needed is a name, so I can blame him whilst resetting it.
lazybloke
Ginger biscuits and cheddar
Leafy Surrey
  • high pressure today, so boiling point might actually be at 100 celcius. Apparently it's usually 99.6
What was the problem again?
marinyork
Resting in suspended Animation
Logopolis
To find out the reynolds number o and strouhal number of accy's kettle.
U
User33236
I would "like" this, but I can't see any mention in the OP that the coffee is instant. Cafetiere and Aeropress coffee both require heating water in a kettle.
As it's accy the assumption it's instant more than likely correct :laugh:
classic33
Leg End Member
Still there, should you require a replacement.
