It’s condensation on the outside not between the glass panes. But I can’t see through the window because it’s so condensated
You can't see through the windows because it's dark (and has been for nearly 2 hours).
You can't see through the windows because it's dark (and has been for nearly 2 hours).![]()
I have a calor gas fire in my conservatory which will put condensate on the inside window, radiators wouldn't do it unless there is absolutely no air flow. Do the windows gave vents?
But I can’t see out of it!
Or get @Accy cyclist round...
That's why i don't have curtains. I'm high up, so no one can see in anyway.on the Plus side no one can see in. Saves on curtains.
Woah there, steady on.
From my experience,the vacuum breaks down after about 10 years.......
..........'Well why don't you clean them from the inside instead". He meant if i cleaned the inside of the windows the outside would come clean!!![]()
that the condensation is on the OUTSIDE, not between the panes
I didn't read most posts when i dived in with my thought. If weez on about it being on the outside of the glass,just get a fecking blade and blade/wipe it off.Well wot we on about den?!I didn't read most posts when i dived in with my thought. If weez on about it being on the outside of the glass,just get a fecking blade and blade/wipe it off.
No he didn't. He assumed you have "side swing" windows, which don't have a hinge.
