Down tube gear shifting
Fab Foodie
Kirton, Devon.
Another small advantage of friction levers at the front is that it's much easier to pick up your chain without stopping if you do drop it
.....aaaaand you can shift a lot of cogs in one hit :-)
freiston
Coventry
My bar-ends are friction-front and index-rear. Up until then, apart from a straight-barred solid back and front mountain bike that I used to have, I had only ever used down-tube friction shifters. I would have to be stuck between a rock and a hard place to go to an indexed front shifter.
midlife
Suntour symmetric, trimmed the front mech automatically :smile:
http://velobase.com/ViewComponent.aspx?ID=4CB7E658-E09E-4950-A283-2787BEAC2BB0&Enum=104&AbsPos=17
youngoldbloke
I find that too. I have lost and picked up my chain and had quite experienced cyclists comment on it like it's a clever trick.
Of course a cleverer trick is to set it up correctly and not drop the thing in the first place ;)
Clever trick if you have to handle it - look around for a large dock leaf or similar. There's usually something handy:okay:
Okeydokey
Okeydokey
I don't seem to have the option of moving the left lever into click mode, a picture of the right shifter I know but where is the aforementioned device?
Salty seadog
Space Cadet...(3rd Class...)
It's the semi circular wire ring. Give it a twist to switch between indexed and friction.
You will only be able to do it on the right shifter. Rear mech
