AyJay
- Suffolk Coast
I have set up my old steel frame road bike in both guises over the years. The bike can be set up just fine with flats even though it is a traditional 1980's race bike frame. I always use bar ends with flats with the position on the bar ends being the same as riding on the hoods. I almost never ride on the lower part of dropped bars due to bad back. In some situations such as riding in town and going down steep lanes I think the flat bar position may actually be better for control.
I have lots of spare components from years of fettling so I can switch the setups including stems at no cost. If you are prepared to experiment with different stems and use bar ends you should be able to get a good setup.
Thank you for your comments. This is more or less how I feel at the moment. I need to take the drop bar bike out to really get to grips with a decision. I also only ride on the hoods. The other thing to check out for me is the different frame geometry of a Boardman flat bar to a drop bar, if any.
