Iainj837
- Shepton Mallet Somerset
I was wondering how do I stop my chain from drying out.
I have to lub it most days dry or wet conditions.
I do 20 plus miles a day, that is just commuting miles.Moodyman said:What lube are you using? How much riding (miles) do you do?
If you use spray lubes they don't last longer than a single short-mid distance ride.
If you use the bottle liquid lubes then you need to get a better quality lube than what you have.
+1pauljonhaz said:I use and recommend this Finish Line wet lube even though it is a wet lube I use it all year round, good in all conditions.
mike.pembo said:+1
I was using some cheap lube from GoOutdoors but it quickly gunked up. I use Finish Line Wet Lube now and the chain looks cleaner and doesnt attract as much muck. It also doesnt need cleaning as often.
