Hi - cheers
1. @ B-onaut - you mentioned a DIY on a brompton board - and you seemed concerned about cutting down seat posts etc. I haven't yet go to looking at it.
2. QR @ handlebar clamp - yes - exactly - i need to twist the handlebars down for folding and this requires a quick release at the clamp. I've done some initial posting on the subject and it's an option people use - eg:
https://www.bikeforums.net/folding-...nd-quick-release-bolt-brompton-handlebar.html
Others share your safety concerns but i suspect it's about sourcing and matching good quality suitable parts. The Andros is designed to be used on a constant basis - so simple QR levers may have that capacity too. With the dutch-telescopic there's still more stability than with a double riser combo. The number of QRs/securing bolts get reduced to just one at the clamp.
3. QR / lock @ telescopic stem - B-onaut mentioned some concerns about the durability of these if i understand correctly - but i'm not so familiar with their failure rate. I'm assuming any used by the guy building it will be discussed and prove suitable. I can see how a welded bar will eliminate the issue. I've not yet posted anything on this subject to solicit wider opinion but as the option exists in components i'm assuming it can be considered as safe to a degree. I guess the degree depends on intended use.
3. In theory i don't need to telescope the riser, Though i wont say no to a handlebar positioned slightly higher than the current H type bar placement. I guess up to another 10mm of height would suffice if feasible / worth the cost. The main thing is that the extended length reaches current h type stem height with m type handlebar mounted. It seems to me any telescopic/welded bar will clear the wheel axle folded.
If i go this route i'll have a chat with the guy who'll be doing it and i guess that will produce the options. I can bring some of this content to the discussion - cheers
sp
sp
), so possibly we do not share the same perspective...
! - how does that look folded i wonder as it looks like its bolted on rather than QR ?
