amasidlover
- Gatley
I've had a Shimano DH-3N80 for about 18 months now and loved the convenience of just having it there and working with no noticeable resistance. However, the QR skewer has seized into the axle and I've had to shim the QR side and tighten the other with pliers to get it tight in the drop outs. I've been taking it to the North West Mountain Bike centre (NWMBC) who have suggested penetrating oil, patience (several days) and a soft nose mallet - all of which I have now tried. They have also advised that the rim is worn. So...
How do I know when the rim is 'too' worn and how close it really is?
The internals (including axle and QR) for the hub are £40 however, the tool to take them apart is £120 (how Shimano justify this I do not know!!) - So does anyone know anyone (ideally in North West England) with one of these tools and ideally the knowledge to use it?
I could replace the hub (and probably the rim at the same time); if I do this then I have some choices:
1) Bottom end Shimano £30 for the hub - more resistance and may well need replacing again in a year or two...
2) Same Shimano hub again £100 for the hub - providing I don't let it get seized again then it should last years, but if it doesn't I may have to replace it as I can't find anyone to maintain it.
3) A (modern) Sturmey-Archer with drum brake £70 for the hub - Can't find any comparisons of this vs the SON hub or the Shimano plus I don't know if the drum brake is compatible with my 105 STI brake levers. But NWMBC do know how to maintain them if there are issues.
4) A SON hub (28 Classic) £160 for the hub - expensive, but nowhere near the differential I seem to remember when I purchased the Shimano.
I think if I need to build a wheel with a new hub then the Sturmey Archer (if compatible) makes most sense, followed by the SON or the cheap Shimano - the equivalent to my old hub is now close enough in price to the SON to make going for the DH-3N80 pointless.
So is there anything I've not thought of and does anyone know the answers to my questions (rim wear, Shimano dynohub tool and SA drum-brake + Shimano STI compatibility)?
Thanks,
Alex
Thanks,
Alex
