I'm looking to get a ebike (Link below.) The problem is, I've heard so many differences of opinion regarding charging the battery up now, that I no longer know which is the best method to keep the battery in good order? The battery states it has 500 charges and some people say you should charge the battery even if it's only lost 20% of it's full charge. So basically charge it back up every time you've used the ebike. If that's the case would that count as 1 out of the 500 charges been used, even though you've only needed to charge it back up 20%?
Then there's other people who say you should let it get down to about 20% remaining and then charge it back up to around 90%. Can someone who know about these batteries help me out here on the correct procedure? Thank you!
https://www.halfords.com/cycling/bi...use-mens-electric-hybrid-bike-17-19-21-frames
