Electric hoists. Can anybody give advice?
slowmotion
Quite dreadful
lost somewhere
In my quest for World Domination , I need to hoist some stuff into my loft. The loft hatch is about 700mm square and I can insert a short length of scaffold pole to support the hoist some distance above the hatch. Something like this one above.^^^^^^^^
It only needs to hoist up nuclear warheads weighing less than 250kg using a two cable pull. Can anybody give me any advice about a good model? They cost from £60 upwards and I'm floundering with all the options. Use will be strictly intermittent. Any and all advice would be most welcome.
Thank you.
Sharky
Kent
Wear ear plugs, in case one of the nuclear warheads explode.
slowmotion
slowmotion
Quite dreadful
lost somewhere
Price limit?
And how much clearance is there.
Unfortunately, World Domination is not quite yet at hand.......the cheaper the better.
Good point about the headroom. I would really like to be able to hoist a crate that is a metre tall through the hatch. Unfortunately, I can't measure the distance from the loft floor to the likely position of the scaffold pole without waking the security guards, but I can give you the data in a few hours' time.
sheddy
Suffolk
now fess up - why are you storing motorcar parts ? this is supposed to be a bike forum !
irw
Quadricyclist
Liverpool, UK
I'd like to echo Milkfloat's concern about the loading on the roof- generally speaking rooves are designed to hold their own weight, plus a bit of uniformly distributed snow.
You say less than 250kg on a two cable pull- does this mean the actual load is heavier than 250kg? Either way, that's a lot to hang off what sounds like a point load on a domestic wooden roof.
Ian
(Certified in entertainment rigging- slightly different scene but the principals and alarm bells are the same!)
