Electric pumps
Binky
I don't intend to carry when riding, purely as a replacement for track pump at home and when travelling.
As I said, I've got a Topeak micro rocket which I have on bike for punctures.
albion
Gateshead
Well, my mega capacity track pump takes about 20 seconds to fully inflate my 700x 45 tyre.
The battery operated compressor I have likely takes at least 2 minutes.
Binky
Time not an issue though at home. And as I'll say again (3rd time?), a small electric pump handy to travel with in bike box.
Widnes
It might be better to get a used one that came with an old car
Cars have had one supplied automatically for some years - so there are a lot of them on the used market
so - a cheap main to "cigarette lighter" convertor and you have one for home use
Binky
Decent shout. Would need a presta adaptor as well but no drama there. They are a fair bit chunkier though than the bike specific ones which be a negative for travel.
Anyway. I'll see what the one is like when it arrives.
I've also ordered spares for my track pump so if I can repair that then I'm well covered.
Just remember that these are high power devices so you must get the puncture fixed the very first time.
Otherwise you are immediately in battery anxiety territory.
I was about to resort to also carrying a battery pack until I then realised the stupidity of it all.
I've been surprised how much charge mine holds despite being tiny (Id get 4 attempts, it wouldn't have to be 1st time) and I've never had to resort to my mini pump or CO2 which I also carry. For the tiny size of it and convenance carry the USB pump in my pocket is a no brainer to add it to my kit.
albion
Gateshead
Yes, I probably got 4 on my road bike though not so on the ebike.
Luckily, the bullet proof tyres I now use makes the pump an afterthought.
super_davo
I would say don't stress about running out of charge (as long as you don't leave it for 6 months without a charge, which if you're using to top up before rides, you won't). It does 4 tyres from flat. If you use inner tubes you'd probably be well out of tubes and emergency patches by this point. If you run tubeless, you're probably not reinflating from flat. I've started carrying a tiny USB C to USB C cable in my saddlebag, with which I can use the reverse charge from my phone to top the pump up, my Garmin, lights, even my Di2 using a tiny little adaptor you can get from AliExpress (in emergencies - I don't make a habit of it...). And all of this is a massive upgrade from the Co2 cartridges many of us took out for years before.
BTW with regards to the suggestion to using the car sized pump, I've got one of those too, and it does work, but I found the cut off was nowhere near as precise at normal road bike pressures. Generally I'd end up with tyres 5 psi higher than I wanted. Could be just my particular 'car pump' but the Cyclami one gets it spot on every time.
Happy_Days
I bought the Cycplus mini one after a good road.cc review on a few sites:
https://www.cyclinguk.org/article/review-cycplus-as2-as2-pro-and-as2-pro-max-mini-e-pumps
Ive used it a few times and it recharges in minutes and I've been happy with it. My only quandary I maybe I should have got the Pro version with a gauge.
I was bought the AS2 Pro version that has a gauge. It’s fantastic—highly recommended.
https://road.cc/content/review/cycplus-as2-pro-mini-bicycle-tire-inflator-308121
Binky
I bought the AS2 Pro version that has a gauge. It’s fantastic—highly recommended.
Looks good. £87 so getting on for 4 times the cost of Cyclami. Then again I haven't received it yet(due today) so it might be utter crap 😂.
Looking at the Cycplus, the Cyclami must have been modelled/copied from it as it looks identical with exact same case and accessories etc. Whether it'll be as good of course is yet to be determined.
I'll update as and when.
On a side note I fixed my old track pump so I'm covered anyway.
Mike_P
Harrogate
This thread on adventure rider
https://www.advrider.com/f/threads/...ami-a3-pro-battery-powered-minipumps.1781751/
takes one of each apart and they are not identical internally; A2 pro max on page 1 and Cyclami A3 on page 2 - this coment is made on the Cyclami
I think this is a very solid and comparable construction to the reference, with 8% more battery capacity costing only about half.
Binky
Pump has arrived and it works. Just tested a couple times and seems good
Only query I have is how accurate is the gauge, has anyone tested against a known calibrated gauge etc?
@super_dave have you checked it alongside a known good gauge?
Or anyone else for that matter
Thanks
