Some years ago, we were having this discussion at work, leave the HW on permanently or turn it off at a specific time each day.You could always have it on constant, but that could work out a little more expensive? (depends also on you cylinder lagging etc), or a sightly larger cylinder may suffice.
I don't doubt what you say but two things are certain in this universe a) perpetual motion is impossible and b) your electrician was a wally.Some years ago, we were having this discussion at work, leave the HW on permanently or turn it off at a specific time each day.
We used to turn ours off overnight...electrician told me that was wrong, keeping a tank hot uses less gas than letting the tank cool down, then having to heat it all back up again.
For 2 weeks (sad innit) I took gas reading daily for each method...and was surprised that his method used less gas.
Not scientific, but it certainly seemed to corroborate his opinion.
edited to say, not sure why I mention he was an electrician..not relevent really.
I was on the same lines and was going to suggest he just insulates the tank really well. The hot water will be kept with no waste then and with no waste you really don't even need to mess about with a timer.Why is the full tank of hot water wasted? Do you have an old inefficient tank? Do you know how quickly heat escapes from it?
Sorry it was a bit facetious. It's very possible that your method isn't using much more than necessary and could be a whole lot more convenient.24/7...365 days a year...mainly because the house is never unoccupied. When we're away, our son is there.
Thomks post got me thinking...
At the time (a good many years ago)...leaving it on was suggested the best option..I monitorwd my useage with both methods...leaving it on appeared to use less gas over a week (simply monitoring units on the meter). It cant take everything into account, cookeruseage etc, but family routine doesnt alter that much, so leaving it on became my prefered method.
Reading the glorious internet, it seems it isnt neccessary after all...but...and its a big but, it surely depends on your hot water useage...and as a family that has shrunk now, there arw STILL 3 baths run EVERY day, plus all the other normal hot water useage.
Wasteful?..in some people's eyes maybe, but baths aee what we like, none of us have every really liked the shower...it about 10 years old and is still like new.
So turning the HW off for a portion of the day simply wouldnt work for us, thered never be enough hot water.
TBF, I'll concede our usage is probably high compared to most so in all probability....ignore my experience![]()
When we moved here in the late 70s(deveopment corporation housing..using modern techniquesfrom the late 60s) some houses nearby had solar water panels. The panels disappeared years ago, failed probably and the council perhaps couldnt repair them...but I like the idea.Fit DIY solar water heating and you'll be burning almost no gas at all in summer.
