Excel help
I used to do this but I've forgotten how...
I've downloaded my bank statement and on the end added a column to categorise spending. So I can add a filter and just see how much I've spent on beer and carrot cake by sub-total.
What I want to do next is a simple graph of each category and the total spend in it. What I'm sure i used to do was pick the category column and the spend column and then it would sum it by category but this no longer works as I remember and I can't figure it: Help!
Midlands
type pivot graph in the help box - its pretty self explanatory after that
edit - best if everything is in columns and has a value
C
Crackle
I knew someone would say pivot tables. I'm damn sure I never used them before but I shall go and read the tedious excel help instructions
Midlands
best I could do on a slow connection
C
Crackle
OK, I get it. Blank rows.
Midlands
you have to fiddle with the properties in the right hand panel - as default it normally counts rather than sums the items
you don't really need to know how - manly just drag and drop
