Filling a hole in exterior render
Dadam
SW Leeds
My Mum's house had an ancient extractor kitchen fan that hasn't worked for years and the housing let in a load of draughts. That is now gone and yesterday I filled the hole with breeze block cut to size and mortared in. The outside wall has what I believe is a sand and cement render with a rough texture like a drying sandcastle. I set the block about 20mm deep. I want to fill this gap and match it with the other render reasonably well. Whatever I do I'm never going to be able to do an invisible repair as roughly 1/4 of the hole had a pebble dash render and I'm not recreating that!
What is the easiest and cheapest way to fill, more or less matching it? This is at the back so is going to be seen hardly at all.
I don't have a photo of the filled hole but here is a before:
oxoman
The pebble dashbit you could just hurl the pebbles at the wet render then push in slightly and brush down once its gone off a bit, thats pretty much how the pro's appear to do it, i believe. The smooth bit just mix sharp sand cement mix up until level and smooth down and its a case of brush with stiff brush and float once its gone off abit. The colouring won't match unless painting, but you should get a reasonable finish.
MontyVeda
as Oxoman says, the pebble dash part shouldn't be at all hard to mimic... it's just some gravel in wet cement on the top quarter of the render.
Give it a go. you've nothing to lose.
nogoodnamesleft
If I were doing it I suspect (for me) it would be matching the render colour rather than the pebble dash render texture. Not an issue if the walls are then painted.
I have once tried cement dyes to change cement colour (for filling between slabs in terrace) which was OK but the colour faded or washed out after a year'ish.
