Hello! Being a proud owner of a new shiny trek hybrid, I have noticed to my horror that I have already scratched the paintwork after only two weeks! How clumsy! Do you guys have any recommendations for some sort of transparent protection that will be easy to remove when desired? Like a tape or sheet that could be cut to size? My main fear is for my front fork as the fork on my last bike is badly disfigured and rust-covered from rubbing against bike racks
poor thing...
I know just how you feel. I’ve used similar tapes to protect against cable run as that is something which really upsets me.
Like you I hate the first scratch. My experience is one often appears early and then there are no more for ages.
Re the rubbing on cycle racks I’m guessing you are using one which hangs on the back of the car and the bike mounts sideways on to the car. These are in my experience very prone to rubbing.
Get hold of some pipe insulation, the dense foam type, cut to legnth and use to cover as much as possible of the rack, hold in place with duct tape. I also keep a few small pieces of insulation to put on the bike frame if there are spots the carrier frame is still exposed. This also helps when two bikes are being carried.
Holding the bike securely in place helps. I’ve found the straps sold for old style toe clips are ideal to secure bike to carrier with no movement or damage.
I love riding my bikes and my enjoyment is enhanced by knowing they are as clean and pristine as possible. Totally anal but that’s where I am with it!!!
