I have an old-style screw-on 6-speed freewheel/block, 14-24 teeth, on my 80s steel Orbit Gold Medal.
I rebuilt the bike recently, but now I can't get the rear derailleur to engage the 24 tooth sprocket. The derailleur is a SunTour Vx shorter cage model, but I had the same problem with the derailleur that I replaced with it - that one was a Shimano of some sort, can't remember now.
The derailleur is fully screwed in to the mount on the dropout.
As it is a problem with both derailleurs and the Shimano one was the original that used to work fine, I'm guessing it's something to do with my new wheels and the position of the freewheel thereupon.
It's not the limit screw, as I can unscrew it all the way out (literally out) and it makes no difference. The other limit screw has plenty of spare tolerance, so I can put the derailleur noticeably further out than the 14 tooth sprocket.
In short, it looks like it would be fine if I could move the whole freewheel block out from the hub by about 3mm, so I'm assuming a shim or spacer between the freewheel and hub is what I need - and I see such things do exist.
But before I buy one, I thought I'd check with you knowledgeable folks in case anyone can think of anything else that might be causing it?
