oldfatfool
Are you sure, can you link to that law please?Illegal too and car should not even be wired to allow this configuration. My car cannot even do this.
Back around 1978 Volvo 200 series were, I think, the first to have daylight running lights (then they were just switched on side lights then)
For fun we used to flash the drivers and watch them get really irate as they were often flashed trying to tell them they had left their lights on. Mostly they waved their arms about and you could see them shouting "I know!!".
Fairly quickly the drivers seemed to have the daylight lights disconnected as they all then seemed to not have them on after a while.
Then there was beeping at any car that was reversing and seeing them slam on their brakes and looking round for a car.
Good headlights aren't supposed to light up the road near the car, they are supposed to illuminate things in the distance. Lighting the road near the car actually degrades your night vision, so you are more likely to miss seeing something that is less brightly illuminated in the distance.I have to admit that I do occasionally use them when its not foggy because the dipped headlights on our Z4 are pathetic: they are properly adjusted, bulbs are good, but maybe because they are so low to the ground they don't really illuminate the sides of the road very well.....
You don't know that....So on winding country roads in the dark I tend to use them to give better visibility as there's usually quite a bit of traffic so full beams aren't an option. They do get turned off again once I'm back on a a road with street lights. I know it annoys some people, but as it isn't actually affecting them and it keeps me a bit safer then I don't see what the problem is.
So that was you was it.... never got irate mind or turned them off Sweden's dark through the winter it made sense .... so is the NE from 3.30pm til 8am.... life's too short to bother with arm waving shouty people. And as for causing mayhem when people are reversing for fun... you should know better OTH
Not according to Kitchin's Road Transport Law.
I think it must be an odd legal quirk. My understanding from reading Kitchin is that front fog lights are an acceptable substitute for dipped headlights (it lays out the regs if you use them like this).I thought it was a requirement but it is not (looked up myself)
BUT when could you legally use fog lights with side lights? If foggy you are required to have main beams on (fogs dont repace this requirement). If not foggy then you must not have the fogs on.
My old KA doesn’t have any fog lights on the front, just one on the back, like others on here I don't get the fog lights on when there's no fog thing.
It is illegal to use fog lights when it isnt foggy.
If you feel a need to improve visibility, you may neeed an eye check, or to drop your speed a bit. Just because others are driving at similar speeds does not mean they are seeing adequately either.I have to admit that I do occasionally use them when its not foggy because the dipped headlights on our Z4 are pathetic:
they are properly adjusted, bulbs are good, but maybe because they are so low to the ground they don't really illuminate the sides of the road very well. So on winding country roads in the dark I tend to use them to give better visibility as there's usually quite a bit of traffic so full beams aren't an option. They do get turned off again once I'm back on a a road with street lights. I know it annoys some people, but as it isn't actually affecting them and it keeps me a bit safer then I don't see what the problem is.
Agreed. I had a rant on this last night. But do note the author is driving a BMW so you do need to lower your expectations somewhat.If you feel a need to improve visibility, you may neeed an eye check, or to drop your speed a bit. Just because others are driving at similar speeds does not mean they are seeing adequately either.
.Fog lights DO affect others, by distracting attention from other potential dangers.
It is an indication of a selfish attitude to admit you are using fog lights as an act of self preservation at the expense of the safety of other road users.
You have to get the timing right to flick to main beam soon enough to blind them back but not too soon that they put on their main beams too!Its imply because these drivers are either morons or complete c**ks , if you get the angle right, a good blast with the main beam gives them a taste of their own medicine. I know two wrongs don't make a right but it certainly makes me feel that little bit better!!
