stumpy66
- Lanarkshire
Im looking for a front light for my tourer, an y recommendations. I have a handlebar bag so cant be bar mounted. Preferrably just a battery operated one, im not looking to use a dynamo hub etc
And a suitable credit ratingExposure Max D Mk 3 or 4. Briiiiight! 1200 or 1400 Lumens. Can be mounted anywhere providing you have a suitable bracket.
You need to be very careful with stuff like that, especially using cable ties. Done badly, it can render any protection a helmet could offer as useless by creating a pressure point which will go straight through the polystyrene n an impact and a snag point which will break your neck rather than slide if you fall off.i use a torch(your choice)cable tied to my helmet it's high up so can be seen well above the height of parked cars,it's not in the way of anything either
Sounds good, its an ortilieb bar bag so should be ok, ill check it out, thanksStumpy,
If you bar bag uses a Rixen and Kaul (Klickfix) fitting you can get an add on for the bracket which lets you mount the light above the bag (provided the bag is on the horizontal)
